Spreadsheet String To Array Function
can someone help me in understanding how to convert the .txt spreadsheet into double array. It looks like the function is only readin the first charater. The vi was working fine (XP LV2011 SP1) before I migrate to win7 (LV2011 SP1).
Message 1 of 8
(7,322 Views)
you are using "d" - this converts to intergers, use %3f for floating point numbers (or %3g %3e %3p etc  - look ate the context help for string conversion formats)
CLD; LabVIEW since 8.0, Currently have LabVIEW 2022 SP1 installed
Message 2 of 8
(7,317 Views)
correct.
I changed that to float %f, but still I only have first character of each string number... what can I do
Message 3 of 8
(7,304 Views)
have you tried:
%.3f
Message 4 of 8
(7,299 Views)
It's your decimal point being a comma, problem.
Message 5 of 8
(7,292 Views)
&$%$$ - I looked at that myself but didn't think it was a comma. Must get eyes checked soon!!
Message 6 of 8
(7,285 Views)
Accepted by topic author oli_dragon
He needs to make his format string %.;%.3f  The %  {period} {semicolon} tells the format string to interpret that string properly with decimal points rather than using the system setting which happens to be a decimal comma since that is what the array is showing.
Message 7 of 8
(7,270 Views)
Great
%.;%.3f works perfectly. thanks guys
Message 8 of 8
(7,201 Views)
