Spyder3 S3-20-04k40 .icd file??
Hello, Can someone kindly provide me the . icd fle for the following camera: Dalsa Spyder3 S3-20-04k40..
Thanks in advance..
chi_visor
Message 1 of 9
(4,107 Views)
Did you try contacting dalsa?
Message 2 of 9
(4,097 Views)
Actually not. I thought it should be available on NI since i could find files for other cameras. I'll check with them.
Message 3 of 9
(4,085 Views)
You can also create your own
NI Camera File Generator
Message 4 of 9
(4,080 Views)
Ive tried using NI Camera File Generator and also configured all the attributes but it doesnt seem to work. I can see the commands working in the test serial settings but it doesnt seem to work when i change it in Measurement & Automation Explorer.
Any idea what could be wrong?
Message 5 of 9
(4,067 Views)
contacted Dalsa. They said thet do not provide support for NI frame grabbers.
Message 6 of 9
(4,057 Views)
Have you soluted this problem? I have a dalsa S2-2X-04k40 linescan camera,but i can't find the dalsa S2-2X-04k40.icd in the Imaq data document. What can i do ?
Message 7 of 9
(3,974 Views)
First of all really sorry for not posting an update on this topic as I have got the solution to the problem by using the NI Camera File Generator.
It did not work for me in the first go. After some tweaking i realized that we have to give some delay after sending every serial command. This can be done in serial settings. It solved all my problems.
@ laogao:
If you dont have .icd file use NI Camera File Generator. I think you should be able to configure it. I would suggest searching the NI database online as well, you might find an update for your camera file.
Message 8 of 9
(3,962 Views)
Hello guys,
I am trying to use thos camera as well, did you guys mange to make it work?? did ysomeone got the file??
Efrain
Message 9 of 9
(3,674 Views)
