Square Division Coding Challenge
Given a square having side length n(where n is positive integer). Write a program to find the smallest number of sub-squares having also positive integer side length, in which the given square can be divided.
Examples:
- n = 2, 4 squares of side 1;
- n = 3, 6 squares (1 of side 2 + 5 of side 1);
- n = 5, 8 squares (1 of side 3 + 3 of side 2 + 4 of side 1)
Giridhar Rajan
Message 1 of 10
(7,443 Views)
I assume you want to revise this challenge to exclude the obvious answer. Every square of side length n can be divided into one square of side n. That is the smallest number isn't it?
Message Edited by Jarrod S. on 10-26-2006 11:56 AM
Jarrod S.
Message 2 of 10
(7,427 Views)
Actually, I'm more interested in seeing a square with a side length that's a negative number. Now that would be interesting! Smiley Very Happy
Message Edited by smercurio_fc on 10-26-2006 12:37 PM
Message 3 of 10
(7,411 Views)
Hmmm... Given the rating somebody gave to my post, guess somebody out there doesn't have a sense of humor.
Message 4 of 10
(7,399 Views)
But... would you still call it a sub-square? 😄
Message 5 of 10
(7,370 Views)
I'm a math major, and we learned first and foremost that there's no conflict of having a set be a subset of itself. Only being a proper subset indicates that the inclusion doesn't work the other way.
Another part of being a math major was looking for the most trivial answers like this to avoid "real" thinking. 🙂
Jarrod S.
Message 6 of 10
(7,357 Views)
A trivial answer deserves trivial code. I was able to significantly simplify your overly complex program. 😄 Just wrap it into a subVI.
I guess somebody will now complain that I allow negative numbers. 😞 Just change the representation to U64 for the most versatile code.
Anyway, back to the problem at hand. Basically, we are looking at a program to compute sequence 018835:
http://www.research.att.com/cgi-bin/access.cgi/as/njas/sequences/eisA.cgi?Anum=018835
There are a few web sites that deal with this problem and writing a solver in LabVIEW seems like a nice challenge.
Here's one I found:
http://www.stetson.edu/~efriedma/mathmagic/1298.html
We are looking for g(n).
Message Edited by altenbach on 10-26-2006 03:18 PM
Message 7 of 10
(7,352 Views)
Guys,
I would like to see a solution in the form of a VI rather than links. Thank You. The Challenge is still open,
Giridhar Rajan
Message 8 of 10
(7,278 Views)
Typically, a LabVIEW coding challenge is an open contest with a submission mechanism, rules, and deadlines, and prizes.
This is not an easy problems and would require significant effort, especially if a grapical display of the solution is desired. If you just want us to do your homework, I guess you're out of luck. What exaclty are you looking for?
Message 9 of 10
(7,246 Views)
hi giri
falgandha here.
i am also in labview and working on dsc module for data aquasition. Where are u and what r u doing?
i want to know more about application control vi which are used in labview in briefly like open vi reference, call library node etc. Can u help me?
falgandha mohire
Message 10 of 10
(7,055 Views)
