Square Wave Frequency Output in Labview
I need an explanation on how to output a frequency of a square wave to a NI 9263 module in labview? I understand how to add the modules to the project, I just need help with the frequency part.
Message 1 of 11
(3,486 Views)
Have you looked at LabVIEW's Waveform palette?  Under "Analog Wfm", where you can find "Generation", and "Square Wfm"?  Or under "Digital Wfm"?  There might even be Examples ...
Bob Schor
Message 2 of 11
(3,467 Views)
Yes, but i do not know where to go from there.
Message 3 of 11
(3,460 Views)
You didn't mention if you are using DAQmx, Scan Mode or FPGA Mode.
For DAQmx, you can refer to C:\Program Files (x86)\National Instruments\LabVIEW 20xx\examples\DAQmx\Analog Output\Voltage - Continuous Output.vi
For FPGA mode, see C:\Program Files (x86)\National Instruments\LabVIEW 2020\examples\CompactRIO\FPGA Fundamentals\FPGA Math and Analysis\Generation\
https://tmesystems.net/
Message 4 of 11
(3,422 Views)
Have you never done any DAQmx (or hardware I/O) with LabVIEW?  Have you never used MAX (the Measurement and Automation Explorer?  Plug your I/O device into your PC and power it up.  Open MAX.  Find your device.  Open a Test Panel.  Use the Test Panels to "explore" your device.
Now read Learn 10 Functions in NI-DAQmx and Handle 80 Percent of your Data Acquisition Applications .  See if this helps.  If it doesn't, find a mentor/professor/smart graduate student and learn about DAQmx and how LabVIEW simplifies getting data from hardware devices.
Bob Schor
Message 5 of 11
(3,413 Views)
I am using FPGA, could you resend the info for the FPGA stuff? I could not open it.
Message 6 of 11
(3,377 Views)
There is no point for me to send the example to you. It is installed on your computer.
Go to Help >> Find Examples >> Hardware Input and Output >> CompactRIO or R-Series >> FPGA Fundamentals >> FPGA Math and Analysis >> Generation
Message 7 of 11
(3,358 Views)
I did not see what you were referring to. Does there exists a VI that would simply allow me to control the frequency of a square wave, and have that output sent to an NI 9263 module?
Message 8 of 11
(3,329 Views)
Not 100% sure what you are driving at, but have you checked out the functions in the Waveform Palette?  Look at the sub-Palettes that have functions for Analog Wfm and Digital Wfm, which include multiple functions for generating Waveforms.  Digital Waveforms, of course, are "pulses".
Bob Schor
Message 9 of 11
(3,318 Views)
Ok, it is actually in a different folder in Example Finder, but you could've explored all the folders and searched for it.
The example is at  Help >> Find Examples >> Hardware Input and Output >> CompactRIO or R-Series >> Signal Generation and Processing >> Analog >> Generation >> Square Wave
Once you have opened the example, you can see how Square Wave Generator is being used. Follow the steps in Moving Examples to a Different FPGA Target to migrate it to your own cRIO. Then replace the FIFO with your NI-9263 output.
Message 10 of 11
(3,299 Views)
