Square teeth movement control
Hi all,
I am new to labview, using labview 8.5.
I want to use Labview to control LANG MCL-2 stepping-motor controller. I managed to get the "square teeth" movement where the movement should be in steps and with each step a measurement should be done, but the problem is I can't figure out a proper condition to apply so the movement will be finished automatically.
Also when the move on X axis is done then on the Y axis, I get a one step backward before it continues regularly, I also want to get rid of this backward step.
Any ideas?!
thnx for help in advance.
Senan
Message 1 of 10
(5,503 Views)
What have you coded so far, can you share your code??
Should not condition be, count the total steps and as you already know the steps/revolution, you should determine when to stop measurement...??
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
Message 2 of 10
(5,484 Views)
I included what I have coded so far. it might be wrong approached...
Message 3 of 10
(5,478 Views)
Dependencies are missing...!!
Missing SubVIs (Square Teeth XY-motion)
Message 4 of 10
(5,467 Views)
ah yes. they r sub VI's related to the lang steppermotor. how can I include them here?
Message 5 of 10
(5,446 Views)
basically all those sub VI's do is to read the command nad put it into actions -mainly steps in X or Y directions- or start and finish the connection with the motor...
Message 6 of 10
(5,439 Views)
those are the missing VI's
Message 7 of 10
(5,397 Views)
Message 8 of 10
(5,396 Views)
more
Message 9 of 10
(5,393 Views)
Those are all the dependencies needed but I edited the main VI to this one
Message 10 of 10
(5,392 Views)
