Square wave analog output (USB6008)
Would anyone be able to provide me with code to generate a continuous analogue square pulse wave (pulse duration 20ms, frequency (0-5Hz) for a USB 6008?
Would be greatly appreciated.
(2,640 Views)
Have you looked at the DAQmx samples that shipped with LabVIEW?  You should find one there called Voltage - Continuous Output.  Maybe this works with your device, I'm not sure.
aputman
(2,604 Views)
Thank you this is helpful. I keep getting the following error related to my clock/timing though. Do you know how I can fix this?
(2,593 Views)
I can't read it.  Picture is too small.
aputman
(2,587 Views)
Apologies, here you go
(2,585 Views)
It means your device doesn't have an onboard clock.  It only supports software timed output.
aputman
(2,571 Views)
