Square wave connected to Convert from Dynamic Data
I have connected a square wave, generated by Simulate Signal.vi, to a Convert from Dynamic Data.vi. The Convert from Dynamic Data.vi is set up for an output of Single Scalar, Boolean (TRUE and FALSE). I have proved to my satisfaction that the square wave is being generated correctly between 0 and 5 volts, the frequency is variable between 100 hertz and 2000 hertz. The problem is that all the Convert from Dynamic Data.vi gives is a 'FALSE' output
(2,830 Views)
The output of the Simulate signal vi is an array. So when you convert to a single boolean, you only obtain the last array value. Either ask the Simulate signal vi to return a number of samples equal to 1, or ask the Convert vi to return an array of booleans.
CC
Chilly Charly    (aka CC)
(2,823 Views)
