Square wave counter (via Trigger and Gate)
I have an application where I am using a pneumatic air solenoid spool valve to apply force to a load cell in a load cycling application.  The signal that controls the process is a 0-1V DC Square wave (frequency and duty cycle are controllable via front panel, typical setup would 0.2 Hz, 50% Duty) I would like to count the number of cycles actually performed.  Attached is a snippet of code where I cannot get the Trigger / Gate + Statistics to count the number of triggers (it is behaving the same as the full vi that I created, where a trigger is not occurring)
NOTES:
  1. Using Labview 8.2
  2. I have tried to copy and past the entire  Trigger Counter example minus the examples signal generation with no success, the cycler seems to stop working.
  3. Full code & explanation posted HERE
Any suggestions would be greatly appreciated.
Thank you for your time
jqm
(2,988 Views)
Never mind, stupid stupid stupid.
Need more coffee.
jqm
(2,982 Views)
