Stack plots displays 9 plots but I only want 3.
What is going on here?
I only want to show the three active plots. I have set the chart poperties to 3 plots shown.
This control in chart properties seems to do nothing as no matter what I set it to the chart shows nine plots.
=== Engineer Ambiguously ===
(2,908 Views)
Right click on our array to cluster functions. They default to nine.
(2,897 Views)
Right click on your array to cluster functions. They default to nine.
(2,897 Views)
Mores specifically, change the "cluster size...".
Clusters cannot have a variable amount of elements, so you need to define what you want.
Message Edited by altenbach on 03-02-2007 08:35 AM
(2,885 Views)
Thanks unclebump, that was it. Smiley Happy
(2,880 Views)
