Stacked Plots Question
I'm working on a project based on the Continuous Data Acquisition
sample that shipped with Labview 7. My problem is that when I try to
plot multiple channels of data using the "Stacked Plot" property of
the Waveform Chart, I still get overlaid plots. The input to the graph
is the 2D array created by the example. Is there any way to get a
stacked plot here?
Many Thanks!
Dan
(4,061 Views)
You might need to convert the array to cluster before feeding in to the chart... here is example for 1D stack plot
Ian F
Since LabVIEW 5.1... 7.1.1... 2009, 2010, 2014
依恩与LabVIEW
LVVILIB.blogspot.com
(4,061 Views)
Hello Dan.
As Ian pointed, conversion to cluster will allow stacked plots whith automatic resizing. I guess NI people should add this property to charts when the input is a n_Dimensions array or waveforms array. Till then, the solution I use is resizing "plot legend" to the number os stacked displays you want to have.
Hope this helps you.
Alipio
"Qod natura non dat, Salmantica non praestat"
(4,061 Views)
Thanks for the reply!
I grew the legend to show more plots, and now have a Chart with
multiple plotting areas. However, when I run my program, I still have
all of the data showing up on the first plot and none showing up on
any of the other plots. The input is a 2D array created by the AI Read
VI. Any further suggestions? I feel like I'm very close!!
Thanks!
Dan
alipio wrote in message news:<506500000005000000C92C0100-1042324653000@exchange.ni.com>...
> Hello Dan.
er os
> Alipio
(4,061 Views)
Oops. I figured out that I had to go into the Scale tab and set each
plot to a different y-axis. Now it works! Many thanks!
As you can probably tell by my questions, I'm a bit of a newbie. Does
anyone have any recommendations for good resources for info on how to
write Labview programs for data acquisition? I got the book "Labview
for Data Acquisition", but I'm finding that it's not all that detailed
or useful. Any suggestions?
Many thanks!
Dan
> Hello Dan.
eforms array. Till
> Alipio
(4,061 Views)
