Stacked charts question
Hi!
I have an application where it would be convenient
to be able to switch between stacked and overlayed
display while the VI is running. Since in LV5.1.1
there does not seem to be a way of changing that
via an attribute node, I could just add another chart
and only show te one I want to see ... so far so good.
However, the number of traces I want to plot varies
and they get really small when I show as many as
could possibly be drawn. Is there a way to select
how many are drawn at run-time?
Rudolf
(2,999 Views)
Hi Rudolf,
What you could do is pass the array which you feed to the graph via the array subset function and control the index and length to limit the number of stacked displays.
Regards
Ray Farmer
Regards
Ray Farmer
(2,999 Views)
Ray Farmer wrote:
: Hi Rudolf,
: What you could do is pass the array which you feed to the graph via
: the array subset function and control the index and length to limit
: the number of stacked displays.
I thought the number of stacked plots was controlled by the number
of visible entries in the legend and not by the dimensions of the inpur
array. Did that change from LV5 to LV6?
Rudolf
(2,999 Views)
