Stacked graph with cursors that extends all plots
I use LabView 2009 9.0f3 (32 bit).. I want to create a stacked graph with two cursors that extends all plots. I can only find the stacked option for chart but not for graph, and I don't know how to create cursors that overlaps all plots. Attaching an image that my college created showing what I want to achieve.
Message 1 of 10
(4,422 Views)
Accepted by topic author mrsound
You can create an array of plots (don't forget to bundle, place them in a cluster first!).
Since properties are identical for array elements, the cursor positions will be the same for all graphs, no matter which one you move.
Message 2 of 10
(4,398 Views)
That's great, thank you!
Message 3 of 10
(4,377 Views)
Hmm, to handle events from graphs in an array doesn't seem to work. Any ideas? I try to listen to to cursor move and range change events inside value change for the array.
Message 4 of 10
(4,368 Views)
Works just fine with dynamic events. Here's a quick rewrite. 😄
Message 5 of 10
(4,358 Views)
Actually, you should place the graph terminal inside the loop, else the "other" cursors don't properly update.
Message 6 of 10
(4,352 Views)
Thanks, this is cool stuff!
I use an event driven state machine and I have placed the event structure in my "Idle" state and I have the graph terminal in my "Update graph" state. Is there any other way to update the other cursors than moving my graph terminal? Maybe the best option is to do my graph calculations in my "update graph" case, but pass the results to a shift register and do the actual graph update in my idle case right before I listen for new events?
What do you think?
Message 7 of 10
(4,327 Views)
Another problem that I have is that I want one graph to show markers and the other graphs to show my signals. I would like to show the markers in a different way and with a different scale than the other signals, but I would like to have the same cursors for all graphs. Do you have any good ideas? Right now I'm thinking about showing markers in each graph as a separate channel in red "point style", but this will probably eat my memory.
Thank you very much for your help so far! Smiley Happy
Hmm, I got an idea! Smiley Tongue Maybe I could use fixed cursors as my markers?
Message 8 of 10
(4,318 Views)
As I said, all graphs will have the same properties and that includes the plot colors.
What you need to do is define multiple plots (e.g. two: a line and a point plot)) and send two plots to each graph as a 2D array. For whatever you don't want to show, make that particular row all NaN. Mix & match! 🙂
Message 9 of 10
(4,302 Views)
Yes, I understood that all graphs in an array have the same properties, but I was thinking that you maybe had other suggestions too. I have already used NaN's for things that I don't want to show up in the graph and it works perfectly. I liked my idea of using fixed cursors as markers and I think that this is the way I want to go. Smiley Happy
Ps. I gave you a couple of Kudos. Smiley Wink
Thank you for all your help! Smiley Very Happy
Message 10 of 10
(4,272 Views)
