Stacking certain plots on a waveform chart
If you have a waveform chart with ten different waveforms plotted on it, it will create ten different stacked plots. Is it possible to have fewer stacked plots and for some to share plots? For example, two stacked plots, one with three waveforms in it, and the other with seven. I've attached an image illustrating what I mean.
If this is not possible using stacked plots, is there any way to achieve something similar to this without creating a separate waveform chart?
Thanks.
(2,419 Views)
Accepted by topic author MilesT
Hi Miles,
LabVIEW charts support either all plots in one chart plot area, or stacked plots with each plot in its own chart area.
Yes: simply place two charts next to each other…
(2,372 Views)
Ah, too bad. I was trying to avoid using two different charts for several reasons. Thanks anyway!
(2,345 Views)
