Staled Array
Hi Guys
Need some help over here
My goal is following
1. Create an array based on values programitlitly beeing passed into the array
2. This should happen everytime  when a boolean value goes true.
3.The array building function should wait 6 s when the value goes true before storing it into the array
My problem is that when i press True, and   start changing the value to desired value before 6 second passes, the value passed to the array after 6 seconds is the start value before i changed to the desired value betwwen 1-6 seconds.
It drives me crazy
And the desired value needs to come inside  from an sequense structure
Se the attached value
(3,339 Views)
(3,330 Views)
