Stand-Alone Executables?
I have developed several LabVIEW applications. I would like to make them
into stand-alone executables (.exe) if possible. Is this possible? If so,
how do I do it. I have LabVIEW 5.1 Pro for Windows and 5.1 for Linux
Derek
(3,232 Views)
If you have the Professional version, it should have Application Builder in
it. You can then make stand-alone applications by selecting, "Build
Application" or "Make Executable" from the "Project" dropdown menu. I am
positive about the Windows version but unsure about the Linux version.
Though, they should both be the same.
Hope that helps. Regards,
Shan Pin Koh
OakRiver Technology - www.OakRiverTechnology.com
(651) 770-8710 ext. 18
(651) 770-8724 fax
Derek Hoiem wrote in message
news:396f24aa@newsgroups.ni.com...
so,
> Thanks,
> Derek
(3,232 Views)
You need the LabView Application Builder version 5.1 which costs the same as
the LabView Base Package here in South Africa.
Rgds
Josua Marais
(3,232 Views)
