Stand Alone executable?
> href="http://www.ni.com/support/labview/toolkits/appbuild/">Application
> Builder Troubleshooting Wizard. That page can provide you with the
> answers you are looking for.
Hi Enrique and other,
i read the website and the helpfile for the application builder, and
have come to the conclusion, that with Labview 6.0 it´s not
possible to build an exe-file with the LabVIEW Run-Time Engine
included (like in Labview 5.1), what means that on a computer
with no Labview installed you need to install the
LabVIEW Run-Time Engine first, before the built exe is
really executable.
Or is there any possibility to include the LabVIEW Run-Time Engine
in the exe-file with Labview 6.0 ??
Grettings, Thomas
(2,721 Views)
"Thomas Junge" wrote in message
news:apndh4$p3f$2@nets3.rz.RWTH-Aachen.DE...
> really executable.
un-Time Engine
Sure, kind of. On the last tab of the application builder is the option to
create an installer. Check the box and it will create a subdirectory
\installer and when you want to install the application you run the
setup.exe in it. It will install both the application and run time engine.
(2,721 Views)
