Stand alone application for 9.0
I am a new user of LabVIEW 9.0 Professional Version (purchased in Feb. 2010) and have developed a VI that I want to run on a laptop.  I have followed the Building a Stand-Alone Application from the LabVIEW help menu and have transferred the .exe to the target PC.  When I attempt to run the application it gives a "requires a version 2009 LabVIEW Run-Time Engine" message.  I downloaded the LVRTE90std.exe and unzipped the files.  I still get the same error when I attempt to run the application.  Can you give a step-by-step instruction of how to create a working stand-alone application.
Thanks.
(3,146 Views)
After unzipping, did you actually run the installer for the run-time? When you built the exe, why didn't you create an installer at that point? It would have included the run-time. In the project explorer, simply click on Build Specifications and select New>Installer. If you are using any sort of NI hardware, you will need to include the driver as well as the LabVIEW run-time.
Never a real good idea to simply copy files from one pc to another. Windows programs in general require you to do an Install.
(3,140 Views)
Dennis,
Thanks for the quick reply.  You ask why I didn't create an installer at the time I built the .exe; please explain how an installer is created at the point of building the .exe?  I don't see that option in the LabVIEW help 'Building a Stand-Alone Application'.  I appreciate any details you can provide as I am just learning LabVIEW.
Thanks.
Roger
(3,125 Views)
As I said, you right click on Build Specifications and select New>Installer.
In the help that I have, there are a couple of links to the 'Building an Installer' topic. See the note under 'Customizing Advanced Application Options' where it talks about the run-time.
(3,120 Views)
