Stand alone executable (including runtime engine) - and Linux question
I have some projects coming up where the OS will run from a CD.
I have two options...
   1. Build an executable that contains the runtime engine so it will run on a machine that does not have the RTE installed. Is this possible?
   2. Install the RTE on an external HDD and tell the executable (on startup) where the RTE is. I need the program to run even if the HDD letter where the RTE is changes.
Question 2: I've been working on a windows machine. Assuming there are no windows library calls... can I copy the project to a Linux LV installation and run it without modifications?
(2,634 Views)
Don't know if this is exactly what you're looking for, but you can create an installer (windows) that contains the run-time engine and any instrument drivers etc. This could also be included on the CD. See link:
https://www.ni.com/en/support/documentation/supplemental/19/introduction-to-the-labview-application-...
-CC
"If anyone needs me, I'll be in the Angry Dome!"
(2,618 Views)
Thanks but no, thats not what I'm looking for.
I dont want to have to run the installer everytime I need to use the program.
(2,612 Views)
