Stand alone labview application (.exe file) does not run properly
@edCubed wrote:
On the computer I developed the labview software on I only made an exe file, I didn't make an installer. I could run this exe file on my development computer but the program did not communicate with my USB power meter.
Next I learned that I had to also make an installer. So I made an installer including the labview runtime engine and installed my program on a different computer. This installed program worked perfectly and communicated perfectly with my power meter.
I haven't actually tried using the installer to install this program on my development computer, but I'm assuming that if I do that it will work on my development computer as well.
Yes, 2 very common problems, i'd say. You can drop VISA-vi's and program the system without having the VISA resource installed, causing the program to look perfect but dont work. Just insert the LV disc and install it all. 😉
The other, as common, problem is to miss the "additional installers" when creating an installer and dont include the VISA, causing the target to not run the program. You can install the VISA from disc on target or make a new installer. 🙂
Been there, done that. Several times. 😉
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 11 of 13
(2,255 Views)
I would like to know, "How could I enable Multi in my computer?"  I have an account through DeVry University.
Message 12 of 13
(2,179 Views)
You have hijacked an old and unrelated thread. Start a new one, please. Explain what Multi is. Do you really mean Multisim? That is not LabVIEW and has a different board. You might also want to first contact your system admin about obtaining the license number.
Message 13 of 13
(2,165 Views)
