Standalone Test Executive incl. testsequence
I am trying to build a standalone *.exe with the Test Executive including the testsequence. The Test Executive can't open the testsequence. I've allready made a new vi with the Test Executive in, incl. the path to the sequence.
What am i doing wrong?
(LabVIEW 5.1/Test Executive 5.1/Appl builder 5.1)
(3,081 Views)
What exactly happens when the test executive tries to open the testsequence? What error messages are you getting? Does it work when being run under the development environment?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,081 Views)
The error is: "in Config Data Read From File.vi->Open Config Data.vi->Read Sequence File.vi->Load Sequences.vi->Open Top-Level Sequence.vi->Test Executive->mytest.vi"
(3,081 Views)
(3,081 Views)
That string is an error traceback from NI's part of the program. It tells you where the error was detected--in this case mytest.vi.
What was the error code number that is reported. That number tells you what the error was that the program detected.
Mike...
LabVIEW Champion
(3,081 Views)
