Start Mobile camera using LabVIEW
Hi all,
I am building one application in which I would be using my Mobile camera (3.2 MP 1600x1200res) to acquire images using Vision VIs at a defined rate, and then process those images in a sequential manner. I am searching for external commands for my mobile to start the camera, but soon as I get it, would I be able to start the camera using LabVIEW/Vision? How can we do it?
Is there any possibility I can build such kind of application?
Thanks!
-FraggerFox!
Certified LabVIEW Architect, Certified TestStand Developer
"What you think today is what you live tomorrow"
Message 1 of 10
(7,500 Views)
What is the OS of your cell phone? If you have the Windows Mobile OS, you should be able to run the Picture Function VIs. In the Picture Functions palette, it has the Camera Capture VI which launches the camera application on the target running Windows Mobile if the target supports picture and/or video capability. You can, then, transfer these images back to a host that supports NI Vision and do analysis on those images there. Have a look at the Picture Functions VIs provided in the LabVIEW Mobile Module.
Adnan Zafar
Coleman Technologies
Message 2 of 10
(7,479 Views)
I have a Samsung S5600 preston series mobile. I could manually send the commands to start the mobile camera.
But my question is, how can LabVIEW transfer the pics fm a non-windows phone?
Another workaround I thought of is to use a memory card and get a way around to acess the card and transfer images to vision....
Pls let me know if there are any more possibilities for this app
-FraggerFox!
Message 3 of 10
(7,457 Views)
Me too want to use my samsung Galaxy s2 8 MP camera with labview is there any possibility for that please reply NI...
Gagandeep.
Gagandeep sharma
Message 4 of 10
(7,085 Views)
HI , Goldy
The following link might help you ..
http://digital.ni.com/public.nsf/allkb/3D9CEA3E7B26FA4586257A56004E4507
I tested it with a “Samsung Galaxy ACE” and it worked perfectly.
Regards. (  Tip: You should use new postings for better help. )
Ing. Jonathan E. Cruz Ortiz
ENERGÍA PROACTIVA S.A.S
Cel : (+57) 3173669343 - (+57) 3124451894
Message 5 of 10
(7,068 Views)
i had tried all that but my cam is not appearing under imaqdx dnt knw why...
ip works perfect but not with labview... 😞
Gagandeep sharma
Message 6 of 10
(7,059 Views)
HI,
1. you managed to install the IP camera adapter?.
2 .if you already I run it, what message goes to press the "Autodetect"?.
3. Did you observe this link? Especially some reported problems with some antivirus. (NOD32 for example).
4. Have you rebooted? "Measurement and Automation Explorer - MAX
Message 7 of 10
(7,047 Views)
@Goldy,
You just bumped up a 4 year old thread! 🙂
The Galaxy S2 could be mounted to your windows system as a mass storage device.
Once you mount your phone as a mass storage device, you can access the the images in your S2 through LabVIEW just like you do it with any other storage device.
-FraggerFox!
Message 8 of 10
(7,033 Views)
I had installed IP adapter and when i click on auto detect it detect the resolution and give a message that camera working ok and pick the resolution of the IP camera settings automatically. but when i press ok it write a notification to reboot the software using camera to see effect.
Then i close my MAX and restart it but i cnt find my camera any where i tried it atleast 1 hour regularly......... 😞 and i daily practice it fr somtime then i leave it bcz no result...
Gagandeep sharma
Message 9 of 10
(7,008 Views)
hi also want to do a draft vision acquiring images from mobile phone, in my case android operating system, if anyone has accomplished this I would appreciate
Message 10 of 10
(6,843 Views)
