Start Multiple DIAdem Versions from LabVIEW
on my PC are installed two different DIAdem Versions (2012 and 2020). I want to start specified Version programmatically from LabVIEW (2017). First part of the Code open selected Version, but I need the DIAdem reference to communicate with DIAdem (run scripts...). When I use DIAdem open reference.vi i get only the reference of DIAdem 2012. How can I switch to the DIAdem reference that I need?
Thanks.
(1,493 Views)
Hello ps cc,
If you trying to refer to DIAdem 2020 version with LabVIEW 2017, it wouldn't work. You should use the 2020 version of LabVIEW
Regards
(1,415 Views)
