Start button for serial data
I want to read data only if i press a start button and stop reading data (even zeros) if i press start button off. How i can do this ?
 I figured out a way to do this.
I don't understand how you are getting zeroes if you hit the stop button.  If you hit the stop button, the while loop then the VI will end.
Sorry for the confusion, it is not stop button i am talking about, if i press the start button of a case structure to off state then i am reading the zeros.
Thanks for your help and time.
Message 21 of 24
(1,384 Views)
I have one more simple question. In My Vi whenever i press a Start button(Boolean push button on) i will store the value in the indicator and when i press stop button (Boolean push button off) it will replace the previosly stored value with the present running values. Is there any way i can store the value in indicator some wher else(in another indicator)  for permanently. So that it cannot get replaced by the present running values.
Message 22 of 24
(1,342 Views)
You could just use another shift register.
Message 23 of 24
(1,334 Views)
I tried using another shift register. But it is replacing the stored value with the present value.
How exactly can i use another shift regiser in my Vi?
Thank you
Message 24 of 24
(1,325 Views)
