Start labview application using different PC from same location
Hallo,
I have built Labview application and put that in Network drive. Every one on this Network can accessed the application. There are two cases regarding on this:
 1. Two PCs with two different User log in want to get access at the same time.
 2. Two PCs with same User log in want to get access at the same time.
Does it work in both cases ?
(2,901 Views)
I don't see why it wouldn't work. But if you have config files of some sort, those could be written to from any computer, which may not be desirable.
(2,890 Views)
