Starting out with NI-DAQmxbase on OS X
I have a NI-6030E board with which I need to do simple I/O under Mac OS X. I am using LV 7.1, and NI-DAQmxbase 1.5 (? I downloaded v1.5 and installed, but I'm not sure how to tell which version I have of mxbase).
To start, I just want to read one reading from a single analog input channel. I tried the example vi Acq One Sample.vi. This read in over 600 sub vi's. It also takes about 2 seconds to run once.
Is this all really necessary to do my simple task? Or is there a faster, lighter way to do this?
(2,341 Views)
Hello Stuart,
You are on the right track.  Your driver, NI-DAQmx Base, is written in LabVIEW and as you have seen, its VIs contain many subVIs.  However, after they are loaded the first time, opening another NI-DAQmx Base program will be much faster.  Also, after you run the program once, each subsequent run shouldn't take quite as long.
-Alan A.
(2,326 Views)
