Starting user programming on a work related project
@dsabene wrote:
I need to eliminate the PXI system at the same time as being able to handle all of the functionality it provides and the flexibility that my boss is looking for.
It's not clear why you need to eliminate the PXI system.  What is wrong with the PXI system?  What about it is causing you problems?  As Jeff B  says, it is just a form factor.  It is a PC with a chassis optimized for handling DAQ cards.
It seems to me there is a problem you need to solve, and the boss is probably saying something like "we need to get rid of that PXI system!" and just using it as a blanket label for what you have now rather than accurately describing the problems you are having now.  A PXI system is flexible since it is a PC.  It can run Windows, or it can run a real-time OS depending on your needs.  And it has the ability to install multiple DAQ cards in whatever arrangements you need to handle all the different test needs.
Message 11 of 25
(1,744 Views)
If I may chime in here... I am guessing it is the cost of the PXI systems that his boss is concerned about. Specially for manufacturing, which is sounds like where he is coming from. I know our manufacturing side hates to buy any capitol equipment. Let alone one for every production line in every facility, as the costs add up really fast.
We do not have a single PXI system here and last time I tried to get one management balked at the cost.
=== Engineer Ambiguously ===
Message 12 of 25
(1,741 Views)
It is not clear to me why we need to get rid of it either but nonetheless that is the direction that I have been given. I am going to dig deeper on this. Believe it or not you all are helping me in my suspicions to the ambitiousness of this project.
Message 13 of 25
(1,740 Views)
True observation. The point of the project it to have a device capable of testing a product with a cost of approximately $300 dollars per unit. As it stands right now, my company can spend anywhere between $20,000 and $50,000 and maybe more for current test stations. I am sure that the brunt of that cost is not just the PXI systems.
EDIT: Can I ask what type of testing scenarios/products does your company develop?
Message 14 of 25
(1,736 Views)
Sounds like ti COULD be a simple as adapting the old version to use a hardware abstraction layer and then implementing a scaled down hardware layer based on lower cost hardware.
For R&D a lot of exotics tests are often done to aid product development research while on the prodcution side quick cheks are "good enough" becuase they are concerened with throughput and all of the "why" questions are left the the design team.
Ben
Message 15 of 25
(1,723 Views)
Ben
Ben,
I feel like it is possible but I FEAR that it is going to be much more code to replace the relevance of the DAQ cards. This is the basis of my originial question of the feasibility of replacing the current LabVIEW test plan and PXI system with straight up LabVIEW code.
Message 16 of 25
(1,720 Views)
One of the beutiful aspect of DAQmx is that the code that uses a cDAQ OR a PXI chassis may differ only in the syntax used to selcted the I/O points.
I had developed some nice code to run a wind tunnel using cDAQ that was latter reused to run a filter cartidge certification fume hood and then latter used to replace and high channel count PXI-SCXI system.
Same under lying code. Only the channel count and configuration options required changing as the code moved from one appltion to another.
The above does not apply to the exotic stuff like routing triggers, and synchronizing modualr instruments of course. That is were YOU need to figure what parts of the current system will be duplicated for your task and the hardware required for those cuntions.
Ben
Message 17 of 25
(1,713 Views)
Ben
Will do Ben, Thank you everyone.
Message 18 of 25
(1,710 Views)
@dsabene wrote:
Ben,
Good!
"Fools rush in where wise men fear to go."
If the original code was developed properly, it could go as I mentioned previously. If the original code sucked then it could be a real pain to adapt and may warrent a rewrite.
Ben
Message 19 of 25
(1,709 Views)
Our main products are UPS's for the telecomunications industry and inverters for alternative energy.
Our production ATE does not require high speed DAQ so we base our ATE stations around the Keysite 34970A/2A DAQ/Switch unit I mentioned before.
Message 20 of 25
(1,706 Views)
