Startup executable run continuosly
Hi all,
is it possible to set a startup executable ton PXI-8100 real target in "Run continuosly" mode?
(4,348 Views)
HI,
Use a  loop 🙂
Regards
Sabri JATLAOUI - Certified LabVIEW Architect - Certified LabVIEW Developer
(4,331 Views)
This is what Sabri means ...
Bob Schor
(4,327 Views)
(4,308 Views)
As a general rule, you should never use the Run Continuously mode, except for specific debug situations.  Using it often means you are constantly opening and closing resources, which should only be done once, PERIOD.
(4,297 Views)
