State Diagram Editor window never appears
When I follow the directions in the State Diagram Toolkit.pdf manual(page 4) and drag and drop a state diagram tool onto an empty block diagram, the editor window never appears, only the block diagram code appears. I bet it's something really simple, but i'm baffled. Thanks for any suggestions.
Win XP
Pent4 2.2G
LabVIEW 7.1 Development System
Already tried reinstalling LView and StateDToolkit...
(2,975 Views)
I haven't used it for awhile but I think you right click on the frame of the case structure or while loop to get the state diagram editor. It really is a nice tool.
(2,964 Views)
"It really is a nice tool."
Ditto that!
I go reaching for it any time I can not "see" the code I need.
In LV 7.1 they changed the operation of the SDE such that only one SDE window can be open at a time. In LV 7.0 you could have more than one open at a time.
Try what Odd_Modem suggested and let us know if it does not show up.
Ben
(2,956 Views)
Thanks for your reply, your answer was correct and embarrassingly simple. Guess I choose a highly descriptive login name...
(2,938 Views)
