State Machine Implementation
How long will the first reading take place?  I recommend initializing a numeric control (in the initialize state) to this value and using it as an input of your READ state.  During the cooldown state, change the value to that for 60 seconds.
Message 11 of 34
(1,549 Views)
Please see the updated VI I uploaded in response to Apok's last post.  The initialize state will now just be done outside the while loop.  I would rather not use a control since this functionality should not be visible/usable by the user.  Thank you for your help.
I surf therefore I am....
Message 12 of 34
(1,543 Views)
Sorry I can't view the VI as I have an older version (2009).  In programming you will encounter a lot of situations where you want to use a control or indicator to store values but don't want the user to see them.  You can either move them off the visible portion of the front panel, or hide them.
right click on the Control- > Advnaced - > Hide Control
Message 13 of 34
(1,540 Views)
Updated State Machine code attached.
Message 14 of 34
(1,537 Views)
ok...here it is, hopefully it represents, take note of the error handling
note: after running it a few times i need to reinitialize the elapsed timer by using a bool shift reg....
Message 15 of 34
(1,534 Views)
Apok,
It looks good so far.  Let me digest the code for a while and tweak it to my specs.  Nice work on using the 'first call' VI that was clever.  I am off for the weekend in a few hours so may not repost until Monday.  Thank you so much for your help on this and other threads you have replied to.  You rock bro!
Message 16 of 34
(1,525 Views)
Any chance you can repost your code in an earler version? I am running 2011 and would like to see what I can learn from this thread to improve my implementation of state machines.  Thanks!
Jeff
Jeffrey Zola
Message 17 of 34
(1,497 Views)
Jeff
ok, this is the new and improved ver9.0...surferEE, just change the time constants of the elapsed timers to suit your needs  Smiley Wink
Message 18 of 34
(1,492 Views)
Apok,
I am looking through your code now and have updated mine from last week.  I have added the DAQ code to give you a better idea of what I am trying to accomplish.  During the 'Read' cycle the DAQ is to output 5V on Port 0 lines 0-2 and take a sample each second for 20 seconds on analog inputs Ai0, Ai3 and Ai4.  These samples are then output to a 2D array.  Each column represents each individual analog channel.  Once I have all 20 samples for each channel, I subtract the first sample from the last sample and output the difference to a numeric indicator.  I have not yet implemented your new code into the VI I have attached.
**Updated:  I have implemented the parts of your code from version 9.  I changed the timing constants as needed as well.  I am having trouble getting the array to build properly and using it after the 'Read' state.***
Message 19 of 34
(1,449 Views)
Jeff,
No worries, I can save to 2011 format once the code is in better shape.  Please email me so the thread does not get hijacked.  I will send you the VI when we are done.
Message 20 of 34
(1,435 Views)
