State Machine Shift Register
Attached is a state machine I created to illustrate a problem I am having with a larger program.  It doesn't do much but the concept is the same.
I created two program buttons (run & abort).  If I abort the count down timer (suspend to idle state) then select run it begins counting down from previous counter value.  I need to begin counting down from 1 min.
The shift register of the state machine while loop retains value when last selecting the abort button.  I need state machine while loop shift register to be reinitialized each time the run button is selected while in the idle state.
Thx
Message 1 of 11
(6,391 Views)
Then feed the constant into the shift register rather than the wire that is going into it now.
Message 2 of 11
(6,389 Views)
sorry i dont get it.  i think you are saying wire the value from the idle loop ?  can you show me what that looks like ?
thx
Message 3 of 11
(6,383 Views)
Accepted by topic author ggress1
There is no "idle loop".  You have an idle case.  Instead of wiring through the count from the left side shift register.  Just feed a constant to the wire that goes to the right side shift register.
Message 4 of 11
(6,369 Views)
Wire the upper shift regsiter also across the inner case structure of the "idle" case and reset it in the true case.
Overall, you should re-think this entire code. It could be made much simpler.
  • I don't think you need the inner while loop, it just constipates everything. Use the outer while loop for this (it is just a different state!).
  • There is an "equal zero" primitive.
  • Why do you need a local variable for the abort?
  • Just place the terminal right there instead. Your VI uses 100% CPU while idle. ...
Message 5 of 11
(6,365 Views)
ok i got it, thanks.
Message 6 of 11
(6,363 Views)
Here's quick cleanup that should give you some general ideas (LV2013). Probably needs a few tweaks.
Of course you could use the high resolution timer to keep track of the countdown clock, eliminating the cntr state entirely.
Message 7 of 11
(6,362 Views)
The inner while loop is there so the "facility reg" control gets sampled at a faster rate than one second.  Maybe there is another method.
Thanks for the input; I will review.  I don't want my code to use excessive cpu resources.
Thx
Message 8 of 11
(6,358 Views)
hey thanks for the code, very streamline compared to my code.  I will reverse engineer it and hopefully pickup some new techniques.
thx
Message 9 of 11
(6,356 Views)
Nobody forces you to use an integer for the timer.
Attached is what I had in mind. Now the countdown is accurate, because it does not rely on any loop rate. Only two states needed.
Message 10 of 11
(6,353 Views)
