State Machine for automatic Resistance Measurement with myDAQ
Develop a Program that automatically runs through the states: Initialize, UsrInfoLeadsImpedance, LeadsMeas,UsrInfoPartsMeas, PartMeas, Evaluate, Store, Quit. It should use myDAQ or a simulation of myDAQ, to acquire the Impedance using myDAQs multimeter-function.
Initialize: In this state, initialize whatever is necessary.
UsrInfoLeadsImpedance: In this State, create a message popup that informs the user to prepare everything for leads impedance measurement (eg: "Plug in Leads to Input... and Input .... and shortcircuit them on the opposite siide of the Leads") After the user confirms, the next state can be entered.
LeadsMeas: In this state, measure the leads impedance 20 times, build the Mean Value and save the data  in the commonly used data Cluste stored in a Shift Register.
UsrInfoParts: In this state, inform the user via a message popup, that the Part (Device under test) should be connedted and it's connection should be confirmed.
PartMeas: Perform the parts measurement function at least 20 times and build the mean value. Save everythin the the data cluster.
Evaluate: Calculate the corrected part value. Display the leads value, the value before correction and the corrected value.
Store: Save away the results in a tet based file for later review.
Quit: deinitialize all and stop the program.
(773 Views)
Accepted by topic author s2210769025@fhooe.at
Seems easy enough. Did you finish it for you class already or do you have any questions?
(772 Views)
No I haven’t finish this and I need help on Labview
(732 Views)
Hi s22…,
So you aren't willing to share your current VI(s) nor to ask specific questions?
When you need help learning LabVIEW: see those Training resources listed at the top of the LabVIEW board…
(709 Views)
