State Machine with Void Loop problem
hello, i need help with the loop i make for the case "Motor Derecha", i dont know how to stop a void loop in the cases for a state machine. That case is the only one with the loop because i'm experimenting to make another project. The buttons i made are just to help and see when they are in a "true" or "false" state and try to stop the void loop.
Thanks for read this.
(2,291 Views)
What is a "Void Loop"?  There is no such term in LabVIEW.
What I do see is that you have a couple of infinite while loops.  The only way to stop them is to abort your VI.  Why do you even have them?
(2,266 Views)
