State Machines
Hi.  I tried to realize the VI suggested in the tutorial
http://www.ni.com/white-paper/7595/en
but as you can see from the VI attached it doesn't work.
In particular, watching at the tutorial, it says:
9.       Right-click the case box at the top of the case structure and select Add Case for Every Value.
I haven't found this option. (i'm using lab2012).
Where is the error?
Another question is he use the same indicator "Money Deposited" everywhere. How is it possible without generating multiple indicators? (I suppose that the indicator is only 1 since he shows only 1 in the first picture).
(3,102 Views)
Try to change the input to Typedef .
Boldness has genius, power and magic in it!'
(3,097 Views)
mmm i haven't understood.. could you explain it better plz?
Ty
(3,091 Views)
Problem solved.
For the String Indicator should be setted the create local variable. Right click on the String indicator connected to the 0 value, create, local variable.
I have also solved the problem with the case structure also if I don't understand why before it didn't work.
By the way thank you
(3,087 Views)
"Add case .." works for Enums, in which case it creates a case for every value in the enum.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(3,083 Views)
