State Space design with pole placement example
Hello everyone,
I would someone to share with me an example using Labview, where some process has been designed using the "state space design method using pole placement". I do not wish for the use of "Mathscript" in it.
Just a simple example using state space with pole placement.
Thanks in advance
(3,240 Views)
Accepted by topic author erfolg2
Have you checked the shipping examples from the Control Design and Simulation Module?
There is this basic example:
examples\Control and Simulation\Control Design\State-Space Synthesis\CDEx Pole-placement.vi
Or as part of a demonstration:
examples\Control and Simulation\Case Studies\Mechatronics\DC Motor\CDEx DC Motor with State-Space.vi
examples\Control and Simulation\Case Studies\Mechatronics\Pendubot\Pendubot.vi
Also, if you browse around, you could see other examples that shows LQG and other control techniques.
Barp - Control, Simulation, RTT and HIL - National Instruments
(3,229 Views)
