State machine Architecture in RT
I use LV 8.2.1 RT DSC, and my target is cFP-2020.
I would like to get some good examples that use state machine Architecture in RT.
I have viewed the RT Module Wizard initial loops, and thats good for a start,
But I would like to see (if possible), examples and learn more.
Sincerely Yours,
Amitai Abramson.
(3,497 Views)
Hi Amitai,
You can find more information about state machines from NI Developer Zone Tutorial: Application Design Pattern: State machines. Don't forget to use the File»New... and explore the other templates that are available. Next, I suggest taking a look at the LabVIEW Example Finder and using the search feature to search for "State Machines". You should be able to find the Test Sequencer.vi example that was made with real-time in mind. Lastly, web searches for "State Machine LabVIEW" produces good results.
Joshua B.
(3,453 Views)
