State machine gets jammed (small problem)
I have a problem with state machine, I atteched dummy code that my problem can be seen. When I hit the exit button and pop-up menu appears, YES button works as it should but when I hit NO, my program gets jammed. I have tried to initialize controls but no effect
Thank you for your help.
(4,156 Views)
OK, so the Event Structure in measure also has an event case for Exit.  If you edit that case it has a check mark in the 'Lock front panel until event case for theis event completes'.  Since your loop never goes there, it never completes.  If you un-check that, it works.
(4,145 Views)
Accepted by topic author Pesonen
I think it will be easier to use one event case stucture.
Jean-Marc
(4,135 Views)
You should try unchecking that checkbox for all your events in all the event structures.
In general, it is a bad idea to have multiple event structures where different structures have events handling the same case.
(4,131 Views)
try this
Gaurav k
CLD Certified !!!!!
Do not forget to Mark solution and to give Kudo if problem is solved.
(4,125 Views)
Thanks for great solutions. That helped a lot. 🙂
(4,110 Views)
