State machine- when is it too big
Not to throw a wrench in things, but I have come to disagree with the idea of calling this concept here a "state machine." It is really a sequencer. States generally can end in "-ing" such as "Initializing", "Shutting down", "Stepper Motor Moving", etc. Now based on your "state" you can respond differently to different messages, requests, and so on which potentially send you through a different sequence. For instance, I am shutting down, so if I get a start test message, I ignore it. I may handle that different if I'm in the idling state, and different still if I am in the testing state. These two things, state machine and sequencer, are being interchanged fairly often and I think making this distinction is important.
If you start feeling you have way too many cases, one thing you can ask yourself is "could I just put the SubVI right here -- do I really need to have an entire case for 'turn on instrument, turn off instrument' etc?" I can tell you that as of late I have erred on the side of just dropping the SubVI right where I need it, in most situations, because it doesn't send me from case to case to case trying to follow the code which a sequencer would. Sometimes I do need a sequencer, so I use it, but I still am always asking myself this "do I really need it" question.
Edit: One important thing I forgot -- State machines often require passing, you guessed it, state, from one loop iteration to the next. And poor management of mutable state can turn into a nightmare when it comes to having multiple parallel loops running. So there is that, too. I have been focusing a lot on minimizing mutable state lately, avoiding putting too much in parallel when it can be in the same loop, and maintaining system state in a single location. It is quite remarkable how much easier it makes application development and debugging..
Message 11 of 13
(1,347 Views)
Thanks to everyone for your help.  GregFreeman, I do agree with you that this is less of a state machine than really  a sequencer.  I am using many sub VI to create modular programs that direct the instrument to perform a specific tasks.  Some of these instrumetns tasks are very simple like having labview send a serial string command then revert back to the idle state to wait for the next instruction.  Some of the instrument tasks are much more involved and require many sequencial commands to complete that task so I have created subVI's to make them modular.    One of the reason I was thinking about doing this with a state machine or a queued state maching would be to make the code much more readable.  Each state would be limited to one or two of these subVI's that is specific for that task.  I also thought the state machine would be easier to expand in the future, I just didn't know if it was a bad idea to have 20 or 30 states.
Thank you
Danny
Message 12 of 13
(1,317 Views)
To me 'too big' is about comprehensibility more than number of states. In your case, you have many states but there's nothing difficult to comprehend- it's just a separate state for each subVI you call.
I would just have a single state called 'running SubVI' - then within that single state a case structure to select which subVI to run. That's a lot cleaner IMO and decouples the number of subVIs from the complexity of the state machine.
Message 13 of 13
(1,268 Views)
