Statechart input cluster appearance
I was wondering if there was any way to change the vertical order of the individual inputs in the input cluster of a statechart caller VI. Thank you in advance.
(3,560 Views)
Accepted by topic author AsperAstrum
You can change the vertical order of inputs in the input cluster by editing the order of the controls in the input cluster.  Open the cluster to edit it and then right click on the border of the cluster and select Reorder Controls In Cluster from the menu.  Now modify the order of the controls, 0th control will occur first in your list, etc...
-Christy
(3,536 Views)
Excellent,that´s what I was looking for. I was trying to do it from the Caller VI instead of the Inputs.ctl. Thank you very much.
(3,521 Views)
For more informations go to: How Do I Change the Order of Elements In A Cluster?
(3,503 Views)
