Static IP adress for sbRIO
I want to set the IP adress of my sbRIO-9607 to a certain value. The IP adress should be static. I tried to do this in a SubVI, there is a screenshot attached to this post. Whenever I try to run the VI, I get an error :
Fehler -2147220609 bei nisyscfg.lvlib:Save Changes (System).vi:1280001
NI System Configuration:  (Hex 0x8004037F) A property contained a value that is not valid or is out of range.
When I remove the 'IPAddrMode' from the property knode, I don´t get an error, but the IP-adress stays the same.
I would appreciate your help.
(3,790 Views)
seems like you have a pretty unknown IP range. What happens if you try a standard IP adress like 192.168.1.1? Same error?
Christoph
Staff Applications Engineer
Certified LabVIEW Developer (CLD), Certified LabVIEW Embedded Systems Developer (CLED)
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved
(3,749 Views)
Hi Christoph,
Thank you for your reply.
somehow the version I posted now works, but I really don´t get why the error occurred. I didn´t change anything in the Software Smiley Indifferent
GM_1
(3,747 Views)
