Static VI reference of reentrant VI
Is it possible to use a static VI reference to dinamically launch a VI as reentrant?
I found this old post, http://forums.ni.com/ni/board/message?board.id=170&message.id=120367, the user found a workaround but it's ugly, isn't it
Message Edited by Snamprogetti on 11-03-2009 02:29 PM
Message Edited by Snamprogetti on 11-03-2009 02:30 PM
(3,836 Views)
Accepted by topic author Snamprogetti
The last snapshot in your link does show the best way to invoke an instance of a reentrant VI dynamically. The one thing I would change from that is to use the VI Name property instead of the VI Path property to wire into the Open VI Reference. You can use just the VI name if the VI is in memory, which is more efficient. Since you have a Static VI Reference, the VI will definitely be in memory.
I agree it's a little ugly. Personally, I created a subVI to hide the ugliness and make it feel more straightforward! 🙂
Message Edited by Jarrod S. on 11-03-2009 08:01 AM
Jarrod S.
(3,816 Views)
In LV 2009 it is now possible for a VI to directly call itself.
Ben
(3,812 Views)
I learnt this thing new today. Thanks a lot Ben.
(3,805 Views)
ben,
That is grt. So no more "you cannot use "sub.vi" recursively" message eh? nice
(3,760 Views)
