Static event structures
I have started to use event structures to call local VIs to a sub panel and have made some progress but have now got stuck. Does anyone have any static event examples which are better explained than the NI examples and on-line help?
Certified LabVIEW Architect and LabVIEW Champion specialising in Noise, Vibration and Harshness
(3,006 Views)
Can you be a little more clear on what you are trying to do, and where the problem lies? It sounds like you want some user action to trigger an event, and inside the event-handling case you want to load different VIs into a sub-panel? Is that correct? What part is proving to be difficult?
J
Jason King
LabVIEW R&D
(3,006 Views)
Yes, you are correct. To be honest I have made more progress now and feel happier about what I am doing. If I get any specific problems I will post again. In the meantime, thank you for taking the time to reply.
Malcolm
(3,006 Views)
