Status bar disappeas when running the code as executable
Hi !
In my application I included a status bar (ActiveX component) filled with different pieces of information (date, current user, etc...). As long as my code runs as "source code" => no problem !
But when I build an executable and run it, the status bar disappears but I still can see the strings included (date, current user, etc...) ; so it's like it becomes transparent...
Anyone has an idea to fix that problem ?
CLA, CTA, LV Champion
View Cyril Gambini's profile on LinkedIn
This post is made under CC BY 4.0 DEED licensing
(3,265 Views)
hmm strange,
is it on the same computer?
If not it could be another OS theme issue.
On the same PC you might have to do some automatic configuration of the ActiveX toolbar, this could be statically remembered in the LabVIEW development environment.
Ton
My LabVIEW Ideas
(3,254 Views)
Hi Ton P,
As you said it's strange ! The executable has been tested on the same and on other computers. And each time the status bar disappears...
What configuration do you suggest for such ActiveX control ?
(3,244 Views)
I have no idea!
It depends on your activex widget.
Ton
My LabVIEW Ideas
(3,225 Views)
I don't know if this could help you, but I've got the same problem with the .NET Progressbar component. To solve the problem I have to explizit make a Manifest-file which explizit loads a certain .NET assembly version. Here is the content of the Manifest-File - maybe it will help you:
<?xml version="1.0" encoding="UTF-8" standalone="yes"?>
<assembly xmlns="urn:schemas-microsoft-com:asm.v1" manifestVersion="1.0">
  <trustInfo xmlns="urn:schemas-microsoft-com:asm.v3">
    <security>
      <requestedPrivileges>
        <requestedExecutionLevel level="asInvoker" uiAccess="false"></requestedExecutionLevel>
      </requestedPrivileges>
    </security>
  </trustInfo>
  <description>Windows Forms Common Control manifest</description>
  <dependency>
    <dependentAssembly>
      <assemblyIdentity type="win32" name="Microsoft.Windows.Common-Controls" version="6.0.0.0" processorArchitecture="*" publicKeyToken="6595b64144ccf1df" language="*" />
    </dependentAssembly>
  </dependency>
</assembly>
HTH.
Best Regards,
Joachim
(3,219 Views)
