StellarisWare VI-s
Hello!
I have installed LabVIEW 2011 Embedded Module for ARM to program my Stellaris board, but I can't find the StellarisWare VIs and the Display VIs.
Only ARM Simulation Signal Generation VI-s. Where can I get the rest of the VIs? Or I installed a wrong package?
Thank You in advance!
(2,557 Views)
Hi gbvbalint,
Did you receive the error when you are trying to deploy the code?
Have you try the solutions mentioned in the following link: http://digital.ni.com/public.nsf/allkb/E47C5D76D1D3E80786257981006A6B98
Presumming that both of the missing VIs are related to the EK-LM3S8962 drivers. From that link, it mentions that LabVIEW 2011 and later Embedded Module for ARM does not install drivers for the EK-LM3S8962 by default. It is however always available to be added as a target to a LabVIEW project once the Module is installed, but in order to properly use the board its drivers must be installed. You will receive the errors mentioned in the link if you don't have the drivers on your computer.
Refer to the link I attached to this post.
Hope it helps
Warmest regards,
Lennard.C
Learning new things everyday...
(2,529 Views)
