Stepping up input in intervals
Hello, I'm currently trying to step the frequency in intervals, i.e for the first 10 cycles I want the frequency to be [1,2,3,...,10] this was easily implemented using a shift register. But after the 10 cycles I want the step to be increased by 10, so the output with be [10,20,...100], and then [100,200,...,1000] etc.
Appreciate any help.
Regards Andreas
(2,827 Views)
Use two shift registers.   One that stores the current value.  One that stores the current step interval.  Every 10 cycles, multiply the step interval by 10 and put that into the shift register.
(2,808 Views)
No shift registers 😃
(2,789 Views)
