Hey Busman,
Here's what you need to do.
1. Replace MSlsetup on the machine where VLM runs.  You can download the new MSlsetup from the following website.  The website also has instructions for where to replace it.  This is done on the machine with VLM.
Updated "Create Network Installer" for the NI Volume License Manager2.  Create a network installer for LabVIEW 7.1.  You do this on the machine that has VLM.  You DO NOT need to run the network installer on the machine with VLM, you just need to create it.  You do this by going to Options >> Create Network Installer.  There is also an article in the volume license manager help - Preparin
g Software for Network Installation which talks about this in more detail.
3.  Once you have the network installer created then on the machine with LabVIEW run Mslsetup.exe.from the network installer folder (this is the folder created by the Create Network Installer wizard). Mslsetup.exe relies upon other files found in the folder which contains the network installer. You do not need to run setup.exe.  You need to do this on the machine with LabVIEW.
To verify that this worked check the license manager configuration per instructions above.  Do this on the computer with LabVIEW.
This configures the computer with LabVIEW to look at the machine with VLM for licensing information.  You will still need to grant permission for the computer in VLM.  Refer to the VLM help for instructions on how to grant permissions for a particular computer.
I hope this helps!!!
Please let me know if you have any questions.
Sarah Miracle
