Still having major problems with serial port communication
For those of you that saw my earlier post I'm still trying to write to pin 3, but have yet to even be able to write in general. I tried wiring up a simple VI to just send "A" but the vi failed and produced a very abnormal error. I tried running the two example VI's concerning serial port communication that were provided with labview 7, but they didn't work either and I always get the following error:
Error -1073807202 occurred at Property Node in VISA Configure Serial Port (Instr).vi->Untitled 1
This error code is undefined. No one has provided a description for this code, or you might have wired a number that is not an error code to the error code input.
Does anyone know what this means and how to deal
with it?
(2,513 Views)
Try uninstalling NI-VISA and Reinstalling NI-VISA and see if that helps at all...
Good Luck
Dan
(2,513 Views)
I plugged that error code into an error out indicator and got the following: "VISA: (Hex 0xBFFF009E) A code library required by VISA could not be located or loaded.". That points to a bad or incomplete installation of VISA. What version of LabVIEW and VISA are you using? Check MAX - Configuration>System>Software>NI-VISA.
(2,513 Views)
