Stimulate and simulate a Transfer Function with a generated sine signal
Hello everyone,
I am able to generate a sinusoidal signal that has a variable frequency depending on what the user has recorded before the experiment. My objective is to draw with several points (red) the Bode diagram of a transfer function stimulated by my sinusoidal signal
This Bode diagram will be then filled in another document where the necessity to keep on the curve all the points after each incrementation of frequency.
Can you help me on my problem ?
Thanks in advance
Message 1 of 1
(936 Views)
