Stop Output 5V
Friends,
I need help here.
I have output of 5V by wiring True to my DAQ assistant. The DAQ assistant is inside a while loop.
I want to stop output 5V when I press the while loop's "STOP". In other words, I want to wire False to DAQ assistant when I press the while loop's STOP. How can I do this ? Thanks !
(3,082 Views)
wire the stop button with an invert to the DAQ assistant
UnCertified LabVIEW Student
Mistakes are for learning, that's why suggestions are always welcome!
(3,074 Views)
Hi poker,
usually you output a FALSE after the loop has finished (in the cleanup part of your VI/program!).
And even more usually you want to use "real" DAQmx functions instead of the ExpressVI...
(3,066 Views)
