Stop While loop
Hi
I have a while loop with a cycle time of 100 sec, when I stop it I have to wait 100 sec untill the while loop stops.
There is any manner to stop it immediatly?
Message 1 of 13
(5,783 Views)
Change the implementation, so the wait is 1 ms and the functional code is only executed every 100 ms.
André (CLA, CLED)
Message 2 of 13
(5,780 Views)
Hi
This is not clear for me...
Can you explain better?
I send my code..
Message 3 of 13
(5,777 Views)
Why are you using a property node for a control that is not accessed within the loop?  And the conditional terminal is set to run if True.
Your while loop doesn't make sense.. Can you post the entire code (attach your vi) and explain what you are trying to do?
R
Message 4 of 13
(5,763 Views)
Hi, enzo,
You can do something like this:
Andrey.
Message 5 of 13
(5,760 Views)
I`m using  aproperty node because I run more than one while loop at the same time and I want to stop them whith  only one button.
Message 6 of 13
(5,753 Views)
Is this what you are looking for?
Message Edited by muks on 07-09-2008 07:46 AM
Message 7 of 13
(5,730 Views)
The while can have any delay in the above vi but it will stop the vi execution immediately the stop button is pressed.
Message 8 of 13
(5,727 Views)
No I don`t want to stop all the VI but only the while loop.
Message 9 of 13
(5,713 Views)
Please post your code so that we may suggest an appropriate solution.
If you have multiple loops running in parallel, you may need one that has an event structure.  We'll be able to determine that after seeing your code.
R
Message 10 of 13
(5,709 Views)
