Stop a sub VI from main VI
You are correct. The default value when you obtain the notification should be False. Fix that and it will work as described. The timeout of 0 is nice because it does not introduce delay into the program. this is intended to be used in something like a free running loop that needs to be notified when to stop. This is checked at the end of each loop iteration. You really don't want to have an arbitrary delay which will slow the loop down.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 41 of 41
(615 Views)
